German Translation
This is the place for any plugins, posts or other useful tools you have created.
djmad
German Translation
Post by djmad »
Hello
There is my Translation to German
(Its partly translated by machine, partly by hand)
Just create DE Folder in Languages and copy the .mo file into
the .pot file is included if you need to make some changes
you can open with freeware Poedit (google it)
Its about 90% correct, Inputs are tested and are working
greets djmad
File is free for changes, if mistages found please correct and repost
License CC-SA
Messages_German.zip
Copy the .MO Files into new created DE Folder
(67.92 KiB) Downloaded 458 times
mgolec
Re: German Translation
Post by mgolec »
Hello! i am also interested in German Translation.
Does the attachment exist? Can you send it to me please?
Greets Markus
hans
Post by hans »
Hi djmad,
is that the translation that is included in the official package? If yes, I would like to correct it. Beside some spelling errors there is also a functional wrong translation...
Best
Hans
You can edit the translations. Install the development version of SheetCam then take a look here <https://www.sheetcam.com/language> for instructions on how to edit a translation. I would welcome any corrections to the translations.
hans
Post by hans »
Thanks.
But am I right that there is no development version for Linux?
The Linux version is currently a development version that is a few releases behind the Windows development versions.
If you want the latest dev you can run the Windows version using Wine. Most distributions include Wine.
hans
Post by hans »
Hmm why is the development version required? The language files are still included in every TNG version I have installed.
But your tutorial with poedit don't work so. I had to convert the *.mo-files to *.po-files to be able to edit them with poedit.
For other users simply run
msgunfmt de.mo > de.po
msgunfmt is part of Poedit.
No I am working on the translation...
hans wrote: Fri Dec 11, 2020 8:44 amHmm why is the development version required?
Dev is planned to become the new stable in January. It has quite a few extra strings that won't be in the current stable translation.
Hmm, looks like I need to check my installer. It should include the po files.
hans
Post by hans »
Still working on the translation..
In which context is "Peripheral feed rate" appearing?
Just want to know this to be able to translate it correct.
The same for:
&Add breakpoint
Acceleration distance
Jolbas
Post by Jolbas »
"Peripheral feed rate" is a path rule. I haven't tested and I can't find it in documentation. But I think it applies to outer and inner radius so that the feed is constant on the parts edges instead of at the center of the tool.
djreiswig
Post by djreiswig »
I think Add Breakpoint is in the post editor.
This is a rule for milling/routing. When cutting a stright line the feed the cutter sees and the machine speed are the same. However when machining small holes the outside of the cutter is moving faster relative to the work than the commanded speed. Applying this rule adjusts the feed rate to compensate.
&Add breakpoint
This is in the post processor editor. You can mark break points in the code. When the code is running and hits a break point it stops so you can look at the variables. This is very useful for debugging.
This is used in the laser plugin. It is the distance it takes the laser to accelerate up to cutting speed.
hans
Post by hans »
Okay nice, thanks.
But a lot of work. There are so many errors in this translation I never would have expected.
It seems that this translation is not based on the translation of the earlier non-TNG version. Isn't it? That version was better I think.
While translating I discover sometimes new functions.
In menu "Operation -> Operation table" there are tabs for Contour, Pocket, Spiral pocket and so on. But every tab shows my spiral pocket. Should that be so? If yes, I haven't understood the function of this window...
hans
Post by hans »
Can you manage it that there are two different fields for 'thread mill'? Because in german there are two different words.
I can but the problem is that it would break all of the other translations. Is it possible for you to work around it?
