Save path rules with part?
SeanP
Post by SeanP »
Would it be possible to have path rules saved with the the part?
The operation on the part saves but with no path rules, it would be useful.
Sean
SeanP
Post by SeanP »
Did it again today, loaded a saved part to a different sheet and missed adding the rules that were with the original part on the last sheet, did you have any thoughts on this Les?
Cheers
Sean
Sorry fro the delay in replying. Rules are saved with the job. The problme with saving rules with the part is that different parts may use different rules. You could easily end up messing up the rules on one part by loading a different part.
SeanP
Post by SeanP »
No problem, I see what you mean.
On a side note to that, I have had 'use default toolset ticked' does that apply to rules as well?
If that's the case that explains why some older jobs can't find there rules after I renamed them all :D
I've since gone back to saving toolset with job option.
Cheers
Sean
