Thank you for the wonderful work you do! I really like SheetCAM, I like it
a lot...
I've just discovered something. I use a contouring operation for my laser
with the DXF post but if I don't pay attention and there are two or more
passes then there is a duplicate layer of lines under each other (clear as
mud?) Would it be possible to output a .dxf that has only one pass (one
layer of lines) irrespective of the number of passes generated by the
toolpath? I can't think of a reason that you might ever want it any other
way (?).
Cheers,
Posted by: "Belli Button" <belli@iafrica.com>
Yahoo Groups Links
<*> Your email settings:
(Yahoo! ID required)
RE: DXF Post
RE: DXF Post
Hi Belli,
Unfortunately it is very difficult to get around that. The post only
knows about the line/arc it is currently processing. It has no way of
knowing if that line/arc is duplicated elsewhere.
On 28/11/14 18:43, 'Belli Button' belli@iafrica.com [sheetcam] wrote:
Yahoo Groups Links
a lot...
way (?).
Cheers,
Yahoo Groups Links
RE: DXF Post
You mean that in future I just have to be more careful when generating a
tool path? I was really hoping I would have someone else to blame...
Cheers,
-----Original Message-----
From: sheetcam@yahoogroups.com [mailto:sheetcam@yahoogroups.com]
Sent: 29 November 2014 19:03
To: sheetcam@yahoogroups.com
Subject: Re: [sheetcam] RE: DXF Post
Hi Belli,
Unfortunately it is very difficult to get around that. The post only knows
about the line/arc it is currently processing. It has no way of knowing if
Yahoo Groups Links
Yahoo Groups Links
Cheers,
Hi Belli,
like it a lot...
laser with the DXF post but if I don't pay attention and there are two
or more passes then there is a duplicate layer of lines under each
other (clear as
(one layer of lines) irrespective of the number of passes generated by
the toolpath? I can't think of a reason that you might ever want it
any other way (?).
Cheers,
Yahoo Groups Links
Yahoo Groups Links
