[REQUEST] Toggle overburn from start point properties.
JohnB
Post by JohnB »
Would it be possible to add turning on/off overburn from the "Properties" screen when editing start points?
Example: I have a square part with 4 holes. I use a "rule" to slow down and turn off DTHC w/ perpendicular lead-ins and a small overburn on the holes for a nice cut. I then select the OD cut start point and change the lead-in to an arc. Without the overburn, one could lead-in/out on a corner keeping it nice and "sharp", but with the overburn it tends to "round-off" the corner.
Yes, yes, I know. I could use layers (as I did before you added the awesome "rules" feature). I just wanted to be "lazy" and see if this could be added.
JohnB
Post by JohnB »
Bumping this in case it wasn't noticed. Thanks
I don't think this would be easy to add. I'll take a look but I can't give any guarantees.
Won't that give you three rounded corners and one sharp one?
