Is there a new Sheetcamtng coming for Linux?
Hello Les,
Is there a new Sheetcamtng coming for Linux? I'm using the latest and it's back at 4.1.11.
Jim
Jim
Just tried the Windows version with Wine.
The install from the downloaded SheetCam TNG Development setup V5.1.12.exe file seemed to work fine..... but when I try running it I get the following errors:
The wibble about OpenGL is probably down to the fact that I'm running it from a remote X-Server but it doesn't seem to effect other things running under wine.... or the native Linux version
If there's something you want testing on this setup to see if it can be made to work (in lieu of a native Linux port of the current version) then please let me know.
russell@cnc:~$ wine "./Sheetcam/SheetCam TNG Development/SheetCam TNG Development.exe"
err:winediag:X11DRV_WineGL_InitOpenglInfo The Mesa OpenGL driver is using software rendering, most likely your OpenGL drivers haven't been installed correctly (using GL renderer "Software Rasterizer", version "2.1 Mesa 7.7.1").
fixme:msvcp90:numpunct_wchar_ctor_refs (0x192460 0) stub
fixme:msvcp90:locale_classic stub
err:module:attach_process_dlls "CamLib.dll" failed to initialize, aborting
err:module:LdrInitializeThunk Main exe initialization for L"Z:\\home\\russell\\Sheetcam\\SheetCam TNG Development\\SheetCam TNG Development.exe" failed, status c0000005
russell@cnc:~$
Running Sheetcam under wine on the native display I get the same error about CamLib.dll
My X-display does have GLX:
Any ideas? or do you have any idea when a native Linux version will get done?
russell@cnc:~$
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGI_swap_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_SGI_make_current_read,
GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
OpenGL vendor string: Tungsten Graphics, Inc
OpenGL renderer string: Mesa DRI Intel(R) 945G GEM 20091221 2009Q4 x86/MMX/SSE2
OpenGL version string: 1.4 Mesa 7.7.1
OpenGL extensions:
<snip>
Bzzzzzzzt. Nope Sorry
Same error after installing that
Are there any debug flags I could use to see what CamLib.dll doesn't like?
Oh dear.... I typed too soon.
None of the file I/O operations work. I can't import drawings, jobs, parts, tool tables or save anything.
Clicking anything in the file menu that actually does I/O (Import Drawing for example) just makes the pulldown menu go away. Nowt else happens. No error message from wine either.
Ho Hum. Looks like using Wine to get the latest version running on Linux just isn't a sane option
