Set Zero-Z-Plane to the bottom
Posted: Mon May 28, 2012 8:05 pm
Hello Folks,
i know i can twiddle around with the tool-length to achieve this, but i think there would be some use for this feature...
I'm talking about setting the Zero of Z to the table instead of the top of the material. This is commonly used on vacuum-tables and stuff like that.
So you don't have to measure the thickness of the material exactly where you are going to scratch for the z-height on every new workpiece, but just save the height of your vacuum-table once (which is equal all over the table) and you are done.
So you don't have to measure thickness of material, no scratching on the workpiece and no cutting in the mats, that lie between workpiece and table
Just start your mill, reference all axes, call offset and start milling
What are you thinking? It is just a little calculation for the software, changing signs for some values and stuff like that. No essential change necessary, i would say?
Or maybe there is a easy and save way to achieve this and i just do not know?
Regards,
Marc
Regards,
Marc
