Sheetcam to Mach3
senemhaskok
Sheetcam to Mach3
Post by senemhaskok »
Hi,
I want to use Sheetcam's Mach3 plug-in but, this error massage comes:
Mach automatic file transfer
If Mach is available, post processed files can be automatically transferred.
Mach NOT detected.
This plugin is disabled.
I can't transfer the G-Codes which I made with sheetcam to Mach3.
I will be glad if you help me.
Agah.
Sheetcam to Mach3
I believe this is a problem with the Mach installer. The only solution I
have found so far is to install a very early version of Mach then
install the latest version over the top of it.
Regards,
http://www.sheetcam.com
On 13/03/2012 11:31, senemhaskok wrote:
Hi,
Mach NOT detected.
Agah.
russ079
Post by russ079 »
Hi, I know this is an old post but, do you know which version of mach 3 comes with the remote plugin ?
Ive tried 3.042 r1.84 r2.48 and r2.63 but non had the remote plugin to use with sheetcam.
Does anyone what what version of mach comes with the plugin or just has the plugin to share?
Russ
rrossetti
Post by rrossetti »
here you go
SheetCamRemote.dll.zip
(6.35 KiB) Downloaded 837 times
russ079
Post by russ079 »
Thanks :D
LoxBox
Post by LoxBox »
rrossetti wrote:here you go
Yay, thanks.
