Hi Less, I was wondering IF the job report could include the x/y extense for the part cut in plasma. This would give us a better grip on costing out the job material wise.
Also wondering IF you could include a costing formula base on material size and thickness and cutting inches and starts.
Maybe a simple plugin to control cost factors?
Thanks For all the hard work, (;-) TP
http://www.forum.sheetcam.com/viewtopic ... 0817#10817
Job report/job costing
X,Y extents are a good idea. I'll add them to the to-do list.
Costing is a bit more tricky. Presumably you would want to work it out from the following:
cost per square inch (based on X,Y extents)
cost per pierce
cost per inch of cutting.
I'll have to think on this one.
http://www.forum.sheetcam.com/viewtopic ... 0818#10818
cost per pierce
Perhaps a small database for the material selction that would allow us to include material cost for each selection.
Then just use the extents for the square inches and the starts and cut inches.
I guess you would also need a cost input for the starts and cost per inch for cuts.
Thanks for the consideration, (;-) TP
http://www.forum.sheetcam.com/viewtopic ... 0819#10819
Came across this on Plasmaspider this morning. Read the post from Vmax near the end.
Would be really interested in this plug in.
http://www.plasmaspider.com/viewtopic.php?f=88&t=16283
