Need to Fix in TNG
Need to Fix in TNG
Thanks. I'll look into it. Hopefully I should be able to fix it fro th next release. -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0664#10664 (http://www.forum.sheetcam.com/viewtopic ... 0664#10664) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0717#10717 (http://www.forum.sheetcam.com/viewtopic ... 0717#10717) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0718#10718 (http://www.forum.sheetcam.com/viewtopic ... 0718#10718) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0719#10719 (http://www.forum.sheetcam.com/viewtopic ... 0719#10719) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0720#10720 (http://www.forum.sheetcam.com/viewtopic ... 0720#10720) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0721#10721 (http://www.forum.sheetcam.com/viewtopic ... 0721#10721) -------------------- m2f --------------------
http://www.forum.sheetcam.com/viewtopic ... 0796#10796
Need to Fix in TNG
Hi Les
you wrote in recent changes for SheetCam TNG V1.1.5
Fixed:
Changed: dxf import more tolerant of errors in dxf file.
It is not corrected my problem isn`t it?
And do anything with rotating, please.
http://www.forum.sheetcam.com/viewtopic ... 0797#10797
Fixed:
Need to Fix in TNG
http://www.forum.sheetcam.com/viewtopic ... 0798#10798
Need to Fix in TNG
Hi Les
Fixed:
http://www.forum.sheetcam.com/viewtopic ... 0799#10799
Fixed:
Need to Fix in TNG
hi Les. I create new topic. I will write here my wishes about TNG. 1)I found bug, if I try in lua plugin to execute this code sc.RunPost("c:\sheetcam.tap","") it works good, and generates "c:\sheetcam.tap" with "Mach3 plasma EMP.scpost" that is my default postprocessor. But if I try execute RunPost with postprocessor as argument sc.RunPost("c:\sheetcam.tap","D:\Programs\SheetCam TNG_\Posts\Mach3 plasma.scpost") it not work. 2) Add "bool quite" argument please to lua and C++ function in TNG bool LoadDrawing(const wxString& fileName = "", bool remember = true) like it was in Sheetcam standard 3)middle button rotates drawing in "View toolpath" mode , but in all other modes middle button scrolls. Can you set scrolling to "View toolpath" mode too? 4)When I change postprocessor file in external editor and after run post, I see nothing changes, but if i do it in internal editor it works. But i dont like use internal editor - so many clicks. Fix please this moment. Thanks -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0577#10577 (http://www.forum.sheetcam.com/viewtopic ... 0577#10577) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0592#10592 (http://www.forum.sheetcam.com/viewtopic ... 0592#10592) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0593#10593 (http://www.forum.sheetcam.com/viewtopic ... 0593#10593) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0594#10594 (http://www.forum.sheetcam.com/viewtopic ... 0594#10594) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0595#10595 (http://www.forum.sheetcam.com/viewtopic ... 0595#10595) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0596#10596 (http://www.forum.sheetcam.com/viewtopic ... 0596#10596) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0597#10597 (http://www.forum.sheetcam.com/viewtopic ... 0597#10597) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0598#10598 (http://www.forum.sheetcam.com/viewtopic ... 0598#10598) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0599#10599 (http://www.forum.sheetcam.com/viewtopic ... 0599#10599) -------------------- m2f --------------------
http://www.forum.sheetcam.com/viewtopic ... 0800#10800
Need to Fix in TNG
hi Les. I create new topic. I will write here my wishes about TNG. 1)I found bug, if I try in lua plugin to execute this code sc.RunPost("c:sheetcam.tap","") it works good, and generates "c:sheetcam.tap" with "Mach3 plasma EMP.scpost" that is my default postprocessor. But if I try execute RunPost with postprocessor as argument sc.RunPost("c:sheetcam.tap","D:ProgramsSheetCam TNG_PostsMach3 plasma.scpost") it not work. 2) Add "bool quite" argument please to lua and C++ function in TNG bool LoadDrawing(const wxString& fileName = "", bool remember = true) like it was in Sheetcam standard 3)middle button rotates drawing in "View toolpath" mode , but in all other modes middle button scrolls. Can you set scrolling to "View toolpath" mode too? 4)When I change postprocessor file in external editor and after run post, I see nothing changes, but if i do it in internal editor it works. But i dont like use internal editor - so many clicks. Fix please this moment. Thanks -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0577#10577 (http://www.forum.sheetcam.com/viewtopic ... 0577#10577) -------------------- m2f -------------------- -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0592#10592 (http://www.forum.sheetcam.com/viewtopic ... 0592#10592) -------------------- m2f -------------------- -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0593#10593 (http://www.forum.sheetcam.com/viewtopic ... 0593#10593) -------------------- m2f -------------------- -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0594#10594 (http://www.forum.sheetcam.com/viewtopic ... 0594#10594) -------------------- m2f -------------------- -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0595#10595 (http://www.forum.sheetcam.com/viewtopic ... 0595#10595) -------------------- m2f -------------------- -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0596#10596 (http://www.forum.sheetcam.com/viewtopic ... 0596#10596) -------------------- m2f -------------------- -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0597#10597 (http://www.forum.sheetcam.com/viewtopic ... 0597#10597) -------------------- m2f -------------------- -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0598#10598 (http://www.forum.sheetcam.com/viewtopic ... 0598#10598) -------------------- m2f -------------------- -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0599#10599 (http://www.forum.sheetcam.com/viewtopic ... 0599#10599) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0631#10631 (http://www.forum.sheetcam.com/viewtopic ... 0631#10631) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0632#10632 (http://www.forum.sheetcam.com/viewtopic ... 0632#10632) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0633#10633 (http://www.forum.sheetcam.com/viewtopic ... 0633#10633) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0634#10634 (http://www.forum.sheetcam.com/viewtopic ... 0634#10634) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0635#10635 (http://www.forum.sheetcam.com/viewtopic ... 0635#10635) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0636#10636 (http://www.forum.sheetcam.com/viewtopic ... 0636#10636) -------------------- m2f --------------------
http://www.forum.sheetcam.com/viewtopic ... 0803#10803
Need to Fix in TNG
Are you sure you meant SheetCam TNG_ ?sc.RunPost("c:\\sheetcam.tap","D:\\Programs\\SheetCam TNG_\\Posts\\Mach3 plasma.scpost")
I'll try to add it to the next release2) Add "bool quite" argument please to lua and C++ function in TNG
Yes. The problem is that 'View toolpath' and simulation are the only two modes where you can rotate.3)middle button rotates drawing in "View toolpath" mode , but in all other modes middle button scrolls
I am afraid you need to tell SheetCam to reload the post. Either you need to restart SheetCam or re-select the post in Options->machine. There isn't much I can do about this. Internally posts work differently to the old SheetCam.4)When I change postprocessor file in external editor and after run post, I see nothing changes, but if i do it in internal editor it works.
Do you mean so many clicks to open the editor? Once it is open, simply saving is enough to force SheetCam to reload the post. You can leave the editor open.But i dont like use internal editor - so many clicks.
http://www.forum.sheetcam.com/viewtopic ... 0804#10804
Need to Fix in TNG
: sc.RunPost("c:\sheetcam.tap","D:\Programs\SheetCam TNG_\Posts\Mach3 plasma.scpost") Are you sure you meant SheetCam TNG_ ? : 2) Add "bool quite" argument please to lua and C++ function in TNG I'll try to add it to the next release : 3)middle button rotates drawing in "View toolpath" mode , but in all other modes middle button scrolls Yes. The problem is that 'View toolpath' and simulation are the only two modes where you can rotate. : 4)When I change postprocessor file in external editor and after run post, I see nothing changes, but if i do it in internal editor it works. I am afraid you need to tell SheetCam to reload the post. Either you need to restart SheetCam or re-select the post in Options->machine. There isn't much I can do about this. Internally posts work differently to the old SheetCam. : But i dont like use internal editor - so many clicks. Do you mean so many clicks to open the editor? Once it is open, simply saving is enough to force SheetCam to reload the post. You can leave the editor open. -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0578#10578 (http://www.forum.sheetcam.com/viewtopic ... 0578#10578) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0600#10600 (http://www.forum.sheetcam.com/viewtopic ... 0600#10600) -------------------- m2f --------------------
http://www.forum.sheetcam.com/viewtopic ... 0805#10805
Need to Fix in TNG
Les Newell wrote:
Yes.sc.RunPost("c:\\sheetcam.tap","D:\\Programs\\SheetCam TNG_\\Posts\\Mach3 plasma.scpost")
I propose to set: middle button -> scroll3)middle button rotates drawing in "View toolpath" mode , but in all other modes middle button scrolls
shift + middle button -> rotate
http://www.forum.sheetcam.com/viewtopic ... 0812#10812
Need to Fix in TNG
[quote="Les Newell"] : sc.RunPost("c:\sheetcam.tap","D:\Programs\SheetCam TNG_\Posts\Mach3 plasma.scpost") Are you sure you meant SheetCam TNG_ ? Yes. : 3)middle button rotates drawing in "View toolpath" mode , but in all other modes middle button scrolls Yes. The problem is that 'View toolpath' and simulation are the only two modes where you can rotate. I propose to set: middle button -> scroll shift + middle button -> rotate -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0579#10579 (http://www.forum.sheetcam.com/viewtopic ... 0579#10579) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0601#10601 (http://www.forum.sheetcam.com/viewtopic ... 0601#10601) -------------------- m2f --------------------
http://www.forum.sheetcam.com/viewtopic ... 0813#10813
Need to Fix in TNG
Check these files please. Sheetcam TNG imports them wrongly.
I use Autocad2006.
I had this problem many times, and decide to write you.
http://www.forum.sheetcam.com//files/dxf2000_214.rar
http://www.forum.sheetcam.com/viewtopic ... 0814#10814
I use Autocad2006.
Need to Fix in TNG
Hi Les, Check these files please. Sheetcam TNG imports them wrongly. I use Autocad2006. I had this problem many times, and decide to write you. Attachments: http://www.forum.sheetcam.com//files/dxf2000_214.rar (http://www.forum.sheetcam.com//files/dxf2000_214.rar) -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0703#10703 (http://www.forum.sheetcam.com/viewtopic ... 0703#10703) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0738#10738 (http://www.forum.sheetcam.com/viewtopic ... 0738#10738) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0739#10739 (http://www.forum.sheetcam.com/viewtopic ... 0739#10739) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0740#10740 (http://www.forum.sheetcam.com/viewtopic ... 0740#10740) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0741#10741 (http://www.forum.sheetcam.com/viewtopic ... 0741#10741) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0742#10742 (http://www.forum.sheetcam.com/viewtopic ... 0742#10742) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0743#10743 (http://www.forum.sheetcam.com/viewtopic ... 0743#10743) -------------------- m2f --------------------
http://www.forum.sheetcam.com/viewtopic ... 0825#10825
Need to Fix in TNG
I normally recommend that you use R12 format where possible. I see the
problem in the other drawings and I'll try to fix it for the next release.
http://www.forum.sheetcam.com/viewtopic ... 0826#10826
Need to Fix in TNG
I use Autocad2006.
http://www.forum.sheetcam.com//files/dxf2000_120.rar
http://www.forum.sheetcam.com/viewtopic ... 0827#10827
I use Autocad2006.
Need to Fix in TNG
I analyze this problem myself, and open that when Lwpolyline group codes (230 == -1) TNG sometimes recognize DXF wrongly.
Correct DXF plugin please
http://www.forum.sheetcam.com/viewtopic ... 0828#10828
