V4.1.16 released
V4.1.16 released
Hi all,
I have just uploaded V4.1.16 to www.sheetcam.com. This version has the following changes:
Fixed: Cut estimate window layout wrong when using a display setting of 120DPI
Changed: Job filename defaults to first drawing loaded if it is currently 'untitled'
Fixed: In tool setup dialog if you change from tap to mill, ramp angle is displayed as 'underfeed'
Changed: The 100 tool limit is now removed. You can now have a virtually unlimited number of tools.
Changed: Tool and process lists now update as you drag the scroll bar
Changed: Plasma loop size slider now allows bigger loops
Note that removing the tool limit involved a lot of changes to SheetCam. If you spot any problems then please let me know.
