G code repeating over Image HELP ??
I have this DXF image and when I run processor it double cuts. The middle part and all the other parts ???
Re: G code repeating over Image HELP ??
Zoom in on your drawing. You probably have a double line. This sometimes happens with an auto trace.
Sheetcam got rid of double line.. I put everything on layers . Going to pen plot it today and cut it if it works .. Pen plotter saves alot of metal...
I just tried the drawing and can't see any issues with it. Did you accidentally set up two cut operations?
Thanks for all the help .. I put everything on separate layers and it cut fine.. Thanks Les
