z raise after plasmacut
I have a problem. When I make a cut it should do a G00 Z15 move after M05, and it does that on the screen, but the machine does not move in real life. And this does not happen all the time either. I have a proma thc and I wonder if its stopping the Z movement or something.
This is not always a problem, but when I am cutting thin sheets it can buckle a few mm and then the torch crash in to it.
Do anyone have a solution? I tried to put a delay after the cut, but that didnt work. Maybe write m101 after each cut?
I slowed down the z acceleration and speed, but that didnt help. And sometimes it raises to the correct hight.... strange. The z ref trigger seems to be working fine also.
Can it have something to do with the height it stops cutting at? If it is a minus value for example at the end of the cut then it may not raise the torch?
It seems that it does not raise the z axis when it is below Z0 at the end of the cut. Anyone else that have the same problem?
I have attached a file, if anyone can find a problem there
- brp120.tap
- (25.75 KiB) Downloaded 95 times
post processor
function OnAbout(event)
ctrl = event:GetTextCtrl()
ctrl:AppendText("Plasma MP1000-THC -ZRef post processor\n")
ctrl:AppendText("Use with floating head (auto touch off) ONLY\n")
ctrl:AppendText("Modal G-codes and coordinates\n")
ctrl:AppendText("Comments enclosed with ( and )\n")
ctrl:AppendText("M03/M05 turn the torch on/off\n")
ctrl:AppendText("Incremental IJ - set in mach3\n")
ctrl:AppendText("The torch is referenced at cut start and every 500mm of movement thereafter\n")
ctrl:AppendText("Designed for use with Mach3 and CandCNC MP1000-THC and Floating head Touch-n-Go\n")
--Post variables:
--refdistance - sets the distance between each reference (default is 500mm)
--switchoffset - sets your net switch offset amount (actual measured switch offset on your table)
--zrefslowdown - sets your distance that the Z uses ref-speed on the touch off. If larger than the Rapid Height it uses Rapid Height
-- modified 10/05/07 by Tom Caudle
-- Based on plasma1.post
function OnInit()
bigarcs = 1 --stitch arc segments together
minArcSize = 0.05 --arcs smaller than this are converted to moves
post.SetCommentChars ("()", "[]") --make sure ( and ) characters do not appear in system text
post.Text (" (Filename: ", fileName, ")\n")
post.Text (" (Post processor: ", postName, ")\n")
post.Text (" (Date: ", date, ")\n")
if(scale == metric) then
post.Text (" G21 (Units: Metric)\n") --metric mode
else
post.Text (" G20 (Units: Inches)\n") --inch mode
post.Text (" G53 G90 G40\n F1\n")
--NOTE: Variable numbers below are in MM and are converted to INCHES by the scale factor
dist = 9999999
refdistance = 10 * scale
zrefslowdown =12.7 * scale
--Put your switch offset value here
switchoffset =3
lastz = 0
if(zrefslowdown > safeZ * scale) then
zrefslowdown = safeZ * scale
function OnNewLine()
post.Text ("N")
post.Number (lineNumber, "0000")
lineNumber = lineNumber + 10
function OnFinish()
endZ = 10
OnRapid()
endX = 0
endY = 0
OnRapid()
post.Text (" M05 M30\n")
function OnRapid()
dist = dist + math.hypot(endX-currentX , endY-currentY)
post.ModalText (" G00")
post.ModalNumber (" X", endX * scale, "0.0000")
post.ModalNumber (" Y", endY * scale, "0.0000")
post.ModalNumber (" Z", safeZ * scale, "0.0000")
post.Eol()
function OnMove()
post.ModalText (" G01")
post.ModalNumber (" Z", endZ * scale, "0.0000")
post.ModalNumber (" F", feedRate * scale, "0.0###")
post.Eol()
function OnArc()
if(arcAngle <0) then
post.ModalText (" G03")
else
post.ModalText (" G02")
post.Text (" I")
post.Number ((arcCentreX - currentX) * scale, "0.0000")
post.Text (" J")
post.Number ((arcCentreY - currentY) * scale, "0.0000")
post.Eol()
function OnPenDown()
if(dist >= (refdistance/scale)) then
dist = 0
-- modaltext (" G00")
-- text(" Z")
-- number (pierceheight * scale, "0.0000")
-- eol()
post.ModalText(" G28.1 Z")
post.Number(zrefslowdown, "0.00")
post.Eol()
post.ModalText(" G92 Z0.0\n")
post.Text(" Z")
post.Number (switchoffset, "0.0000")
post.Eol()
post.Text(" Z")
post.Number (pierceHeight * scale, "0.0000")
post.Eol()
else
post.Text(" Z")
post.Eol()
if (preheat > 0) then
post.Text ("\n G04 P")
post.Number (preheat,"0.###")
post.Eol()
post.Text ("\n M03\n")
if (pierceDelay > 0) then
post.Text (" G04 P")
post.Number (pierceDelay,"0.###")
post.Eol()
function OnPenUp()
post.Text (" M05\n")
if (endDelay > 0) then
post.Eol()
function OnNewOperation()
post.Text (" (Process: ", operationName, ")\n")
if (plungeRate <= 0) then
post.Warning("WARNING: Plunge rate is zero")
if (feedRate <= 0) then
post.Warning("WARNING: Feed rate is zero")
function OnToolChange()
post.Text (" M06 T")
post.Number (tool, "0")
post.ModalNumber(" F",feedRate * scale,"0.#")
post.Text (" (", toolName, ")\n")
function OnNewPart()
post.Text(" (Part: ",partName,")\n");
--Post variables:
function OnInit()
else
dist = 9999999
switchoffset =3
lastz = 0
post.Text ("N")
function OnFinish()
endZ = 10
OnRapid()
endX = 0
endY = 0
OnRapid()
function OnRapid()
post.Eol()
function OnMove()
post.Eol()
function OnArc()
else
post.Text (" I")
post.Text (" J")
post.Eol()
dist = 0
-- text(" Z")
-- eol()
post.Eol()
post.Text(" Z")
post.Eol()
post.Text(" Z")
post.Eol()
else
post.Text(" Z")
post.Eol()
post.Eol()
post.Eol()
function OnPenUp()
post.Eol()
now I know exactly what the problem is. It is when the cut ends and the torch is in a -Z value the z axis dont move.
Can I fix the problem like this: when the torch touches the material it will normally write Z0, but the solution will be to write like Z10 instead. In that way it will always be at a +Z value....?
