Machine save / load...
Davek0974
Post by Davek0974 »
When using machine save & load, is it possible to get the type of machine - rotary or flame/jet to save as well??
Would be good :)
Good idea. It will be in the next dev version.
PK
Post by PK »
I start each "machine" in it's own environment as such:
SheetCam TNG Development.exe -c plasma
or
SheetCam TNG Development.exe -c router
That starts/opens a subdirectory of it's own which holds tools, configs, etc. I have to know which machine I need when starting Sheetcam, but that hasn't been a problem so far.
Paul
Davek0974
Post by Davek0974 »
Ooh, that sounds useful, is it possible to switch to that way after using it in the normal startup config??
Or does it lose all the settings ?
You can use profiles at any time. If the profile does not exist a copy is created from the master profile (i.e when you run SheetCam without -c).
Davek0974
Post by Davek0974 »
Got it, that works very nicely and solves a lot of issues.
Any chance you could add the profile name to the caption -
"SheetCam TNG (Plasma) - My job name..."
Showing teh profile name just missed the latest release but it will be in the next one.
PK
Post by PK »
That will be nice. For now, I just look at the tool list in the left-hand column to quickly see which one I have running.
Davek0974
Post by Davek0974 »
FYI
If you change a running setup from a standard one to a split profile one make sure you replace the NEW Default Tools file with your normal one - the copy of default tools that is created when using profiles for the first time is NOT the one you were using before, especially on plasma I found it lost all the volts settings etc and returned them all to default 49v.
I had not noticed this and had some fun today when running a job ;)
A quick copy fixed the issue but as i said - for future information
That's odd. It should copy the settings from your default profile.
Davek0974
Post by Davek0974 »
It seems have copied the basic part but not the modified stuff for the CandCNC post - volts, tip size etc.
hoangnhatng
Post by hoangnhatng »
PK wrote:I start each "machine" in it's own environment as such:
or
Paul
How do i run that command ?
Davek0974
Post by Davek0974 »
I just created a desktop shortcut for each one and edited the command line inside the shortcuts.
PK
Post by PK »
Davek0974 wrote:I just created a desktop shortcut for each one and edited the command line inside the shortcuts.
Yes - This basically does it. I do this through a launcher, which is similar.
hoangnhatng
Haha I have done. I have a problem when i edit the target to "C:\Program Files (x86)\SheetCam TNG Development\SheetCam TNG Development.exe -c plasma". I search google and change the command to "C:\Program Files (x86)\SheetCam TNG Development\SheetCam TNG Development.exe" -c plasma . Thank you to Davek0974 and PK so much
