Plate Marker Height Problem
I just got my plate marker up and running, or so i thought. I think it is post problem, but the height command for the scribe ends up on the same line as the move. So by the time the move is complete the scribe finally makes it down to the material. Is there a setting i am missing or is my post screwed up? I attached a sample tap file and the post i am using.
- circle.tap
- (540 Bytes) Downloaded 149 times
- Mach3 THC with scriber.scpost
- (9.54 KiB) Downloaded 142 times
