zigzag pocket 0-90 deg
80gus
Post by 80gus »
Im having issues with pocketing when i set the cut to 0 or 90 deg to get straight cuts for the final finish, so the machine marks a parallel or vertical, around complex pictures i always seem to get 1 or 2 lines where (set to 0 deg angle) the step ain't X>>>>>>Y DOWN X<<<<<<<<<Y Down
when changing between y cut height it steps on an angle. seems to be on only small areas with X movement. is there any way i can change that so it is always 100% thane angle i choose? hop that makes sense, as with the bottom left of the attached picture you will see what i mean.
If SheetCam thinks it is quicker to simply move from the end of one part of the pocket to the start of another part of the pocket rather than lifting the cutter it will do so. I have added an option for the next development version so you can force it to always lift for moves.
80gus
Post by 80gus »
Thanks les is that far away!
Hopefully I'l have a new release out in a couple of weeks.
80gus
Post by 80gus »
any progress on this Les.
80gus
Post by 80gus »
Les has there been any progress on this update?
It has been in the development version for a little while. Look for 'Always lift cutter when repositioning'
80gus
Post by 80gus »
Has this option disappeared? I remember using it now can't seem to find it again?
