Hi all,
I have just uploaded Development V6.1.16 to www.sheetcam.com. This
release has the following changes.
Added: 'Always lift cutter when repositioning' option to zigzag cutting.
This stops the occasional diagonal cuts when zigzag pocketing.
Fixed: Missing tool number in milling/routing tool definitions
Fixed: Clicking on an open line from a generated shape will not select
that shape
Changed: Shape mode remembers the last shape selected when you switch to
another mode.
Fixed: 'New job' didn't clear the current shape if in shape mode.
Fixed: Locking up when loading some dxf files with splines.
Fixed: Saving material settings after changing some material parameters
saved the repvious values
Fixed: Post breakpoints only working on edited posts
Fixed: Crash if you click the 'run post' button while debugging a post.
Yahoo Groups Links
<*> Your email settings:
(Yahoo! ID required)
