Rotary milling, like rotarty plazma
80gus
Post by 80gus »
Rotary milling is something i want to get into, is it possible to do if i buy the rotary plugin, if done a bit or research and come up with nothing.
I can't think of any real reason why you can't do this. I don't currently have a rotary milling post but it wouldn't be a major job to write one. Do you want to just mill round tube or rectangular as well?
80gus
Post by 80gus »
Les Newell wrote:I can't think of any real reason why you can't do this. I don't currently have a rotary milling post but it wouldn't be a major job to write one. Do you want to just mill round tube or rectangular as well?
Both, mainly for engraving at this stage or splining axles, i just was hesitant on buying it with out seeing it work first
I can send you a free 30 day license for the plugin. I'll also look into making a post for you. I won't be back in the office until Tuesday but I should be able to look into it then.
80gus
Post by 80gus »
Les Newell wrote:I can send you a free 30 day license for the plugin. I'll also look into making a post for you. I won't be back in the office until Tuesday but I should be able to look into it then.
Thanks Les i sent you a PM
ArchieF
Post by ArchieF »
Hi Les ,
asked you some time ago :
http://forum.sheetcam.com/viewtopic.php?t=6448
Would you sent me a free 30 day license for the plugin,too ?:D
Richard
Hi Richard,
So you did. I'll PM you with a license.
ArchieF
Post by ArchieF »
Les I get this message :
Plugin failed to load : Plugin is unlicensed
Richard
Hmm, I'll try sending you another.
ArchieF
Post by ArchieF »
This one works fine (has one letter more)
Thanks Les
I have attached a post for milling with a rotary 4th axis using the rotary plasma plugin. It should work with both round and rectangular tube.
In RotaryPlasma simulation mode click on the setup button then select the 'mill' machine type.
Mach3 rotary.scpost
(6.62 KiB) Downloaded 834 times
ArchieF
Post by ArchieF »
Works fine here !
Thanks Les
Richard
whirlwind17
Post by whirlwind17 »
So does it mean, already solved?
_______________
Any idea concerning illegal nunchucks
jacala
Post by jacala »
Hello Les,
this is probably a good start for my 4th axis milling.
Could you send me a test license for rotary plugin so I can test if it works for my usage?
I've already posted a new topic about it before I saw this and I think that it would work but ofcourse: lets test it!
First post asking about it:
http://forum.sheetcam.com/viewtopic.php?t=6716
thanks!
Jacala
