Hi all,
I have just uploaded dev V5.1.31 to www.sheetcam.com. This release has
the following changes:
Changed: Added more functionality to Lua API
Changed: Much improved debugger for Lua scripts and posts
Fixed: Graphic display in Wine does not update properly
Added: 'select all outside' and 'select all inside' in contour mode
Fixed: 'Feed rate is zero' in sim when using a move as the first operation
Added: 'Use drawing name as part name' option in drawing import
Fixed: HPGL import sometimes failing to read the drawing properly
Fixed: V carve occasionally producing incorrect tool paths
Yahoo Groups Links
<*> Your email settings:
(Yahoo! ID required)
