im new to plasma tables
General chat and non SheetCam related discussion
jrfab
Post by jrfab »
i have a 10x5 lighting cnc plasma table with a hypertherm powermax 45 plasma and im runing mach 3 im having trouble getting the g-code transfer correctly can anyone help me .
What problems exactly are you having. Do you have the correct post processor selected?
jrfab
Post by jrfab »
[quote="Les Newell"]What problems exactly are you having. Do you have the correct post processor selected?[/quote]
I think I do im having a problem with z axis raising to high im using a 5x10 lightning cnc table with hyper promax 45 with air
First check that Z=0 is at the top of the work. If it isn't, manually jog the torch down so that it just touches the work then click on the 'zeor z' button in Mach.
If this is correct check your rapid clearance height in SheetCam options->hob options->material.
