sheetcam.com Forum Index sheetcam.com
SheetCam discussion board
 Forum SubscriptionsForum Subscriptions    FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
NEW TO CNC AND SHEETCAM
Post new topic   Reply to topic    sheetcam.com Forum Index -> Chat (chat @forum.sheetcam.com)
View previous topic :: View next topic
Author Message
JHOP
PostPosted: Wed Apr 21, 2010 12:25 am    Post subject: NEW TO CNC AND SHEETCAM Reply with quote
IS THERE ANYONE OUT THERE THAT I CAN PAY TO TALK ME AND A PARTNER THROUGH THE PROCESS OF START TO FINISH IN IMPORTING A DXF DRAWING,CHECKING THE VARIOUS STEPS IN STARTING POINTS, START AND STOP POINTS, HOW TO ELIMINATE AND OR MANAGE MODIFYING # OF NODES ON POLYLINES-IN GENERAL HOW TO END WITH CUTTING A USABEL PRODUCT.THANKS FOR ANY HELP YOU CAN GIVE TO TWO NEWBIES--JHOP@AOL.COM
Back to top
View user's profile Send private message
PostPosted: Wed Apr 21, 2010 7:53 am    Post subject: Reply with quote
There are some good video tutorials here http://www.cncinformation.com/sheetcam-videos/. They may help.
Back to top
Big Daddy
PostPosted: Wed Apr 21, 2010 4:02 pm    Post subject: Reply with quote
Yeah, we've been watching those. It seems the version Ivan is using in his videos is a different version than we have. We are using the 2.0.11 ver. right now.
We made some progress last night but still having some issues.
Back to top
PostPosted: Wed Apr 21, 2010 4:22 pm    Post subject: Reply with quote
Yes, it is an older version but most things work pretty much the same. Have you looked at the tutorials in Help->tutorials?
Back to top
Big Daddy
PostPosted: Wed Apr 21, 2010 8:50 pm    Post subject: Reply with quote
Yeah, I discovered a jump between videos. Ivan starts one of the videos with a jet that already has the cut path established. He didn't do that step in the previous video.
The tutorials reference an icon to do that process...but it doesn't look the same in the newer version. Took me forever to find it but I finally found it.
After generating the process I did a dry run with the table and it seemed to do fine but I noticed there are no commands to turn the plasma on or off during the job. I've double checked my post processor settings and have even changed them to a couple others to see if it might generate the code differently to no avail. (It's a Mach3 processor and I see that sheetcam comes with 5 or 6 Mach3 options)
Hope I'm making sense with this.
Back to top
PostPosted: Wed Apr 21, 2010 9:23 pm    Post subject: Reply with quote
Make sure you use a plasma post. If you use a milling post you will get the results you are seeing. Try the Mach3 plasma post.
Back to top
Big Daddy
PostPosted: Wed Apr 21, 2010 10:35 pm    Post subject: Reply with quote
Well, I've tried all three.
Mach3
Mach3 plasma
Mach3 plasma pause
All three give me the same code results of not turning the plasma on and off.
Thoughts?
Back to top
Big Daddy
PostPosted: Thu Apr 22, 2010 12:01 am    Post subject: Reply with quote
I'm sorry Les, I don't know what I'm doing wrong. I can see in the code it inputs the "M03" and "M05" again on all three post options. I've even tried a totally different DXF file and get the same results with each one.
Back to top
Big Daddy
PostPosted: Thu Apr 22, 2010 3:22 am    Post subject: Reply with quote
Sorry Les to be such a newbie on this. I just ran the same DXF file through LazyCam and looked at the G-Code it generated. I was under the assumption that the "M Codes" were only for milling so that was why it was throwing me. It produced the exact same codes, it just labeled them a little more with (Plasma on) and (Plasma off) after the codes.
Thanks for your patience.
Back to top
Display posts from previous:
Post new topic   Reply to topic    sheetcam.com Forum Index -> Chat (chat @forum.sheetcam.com) All times are GMT
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
