sheetcam.com Forum Index sheetcam.com
SheetCam discussion board
 Forum SubscriptionsForum Subscriptions    FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Can\'t get a part into SheetCAM
Post new topic   Reply to topic    sheetcam.com Forum Index -> Yahoo posts (yahoo @forum.sheetcam.com)
View previous topic :: View next topic
Author Message
Lindsay
Guest
PostPosted: Thu Sep 17, 2009 3:06 am    Post subject: Can\'t get a part into SheetCAM Reply with quote
Here's what I'm trying to do. I can load a part into sheetcam just fine. Then I want to offset it from 0,0 by half an inch which I do just fine. Then I want to bring in a 1/4 dia. hole to be cut at 0,0. BTW this is being done on a 4' x 8' CNC router table. The purpose of the 1/4 hole is to index my sheet so that in case a bit breaks or I have to pause and restart I'll have a reference point to come back to. So I want to run two process, one to drill the hole and one to cut the part. I'm using a 1/4" router bit. The problem, the hole won't come in. Nothing appears on the screen and when I try to zoom to part it just zooms out, it doesn't show the hole.I've tried multiple holes and even went to a 0.3" dia. but that didn't come in either. Output is from CorelDraw in AutoCAD 2.5 export as DXF.
Lindsay
Back to top
Display posts from previous:
Post new topic   Reply to topic    sheetcam.com Forum Index -> Yahoo posts (yahoo @forum.sheetcam.com) All times are GMT
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You can attach files in this forum
You can download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
